Aller au contenu principal
Toshiba Satellite L505 Laptop Fan Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L505 Laptop Fan Replacement, Keyboard: étape 1, image 1 de 3 Toshiba Satellite L505 Laptop Fan Replacement, Keyboard: étape 1, image 2 de 3 Toshiba Satellite L505 Laptop Fan Replacement, Keyboard: étape 1, image 3 de 3
    • Open the laptop and locate the plastic strip just above the keyboard.
    • With care, slide the prying tool into an end and lift it up until you hear an audible click, meaning it has separated.
    • Slowly slide a finger or the prying tool under and follow the strip to the opposite end, completely detaching the strip.
  2. Toshiba Satellite L505 Laptop Fan Replacement: étape 2, image 1 de 2 Toshiba Satellite L505 Laptop Fan Replacement: étape 2, image 2 de 2
    • Remove the four screws using the Phillips #1 screwdriver.
  3. Toshiba Satellite L505 Laptop Fan Replacement: étape 3, image 1 de 2 Toshiba Satellite L505 Laptop Fan Replacement: étape 3, image 2 de 2
    • Gently push the clip back as you lift the top of the keyboard towards you.
    • There is a cable connecting the keyboard to the motherboard so do not lift the keyboard all the way out yet.
  4. Toshiba Satellite L505 Laptop Fan Replacement: étape 4, image 1 de 3 Toshiba Satellite L505 Laptop Fan Replacement: étape 4, image 2 de 3 Toshiba Satellite L505 Laptop Fan Replacement: étape 4, image 3 de 3
    • Gently disconnect the connector strip by pushing the white clips forward.
    • Carefully pull the strip out of its port.
    • Remove the keyboard from the device.
  5. Toshiba Satellite L505 Laptop Fan Replacement, Optical Drive: étape 5, image 1 de 2 Toshiba Satellite L505 Laptop Fan Replacement, Optical Drive: étape 5, image 2 de 2
    • Turn the laptop upside down.
    • Remove the screw labeled F4 using the Phillips #1 screwdriver.
    • There are 2 screws labeled F4, the correct screw is the one closer to the hard drive.
  6. Toshiba Satellite L505 Laptop Fan Replacement: étape 6, image 1 de 2 Toshiba Satellite L505 Laptop Fan Replacement: étape 6, image 2 de 2
    • Gently slide the optical drive out of the device.
  7. Toshiba Satellite L505 Laptop Fan Replacement, Battery: étape 7, image 1 de 1
    • Turn your laptop upside down, at the bottom of the laptop, slide the right sliding lock to the unlocked position.
    • Slide the left sliding lock to the left and hold it. Using your fingers lift the battery out.
  8. Toshiba Satellite L505 Laptop Fan Replacement, Palm Rest Assembly: étape 8, image 1 de 3 Toshiba Satellite L505 Laptop Fan Replacement, Palm Rest Assembly: étape 8, image 2 de 3 Toshiba Satellite L505 Laptop Fan Replacement, Palm Rest Assembly: étape 8, image 3 de 3
    • Unscrew all of the screws marked on the underside of the laptop.
    • Remove the screw marked in the second photo by lifting up the lid and unscrewing using a Phillips #1 screwdriver.
    • Remove the three flat screws in the port where the Optical drive is housed in.
  9. Toshiba Satellite L505 Laptop Fan Replacement: étape 9, image 1 de 2 Toshiba Satellite L505 Laptop Fan Replacement: étape 9, image 2 de 2
    • Remove the keyboard and once that has been done, remove the screw marked "16."
    • Disconnect all of the cables with a blue circle.
  10. Toshiba Satellite L505 Laptop Fan Replacement: étape 10, image 1 de 3 Toshiba Satellite L505 Laptop Fan Replacement: étape 10, image 2 de 3 Toshiba Satellite L505 Laptop Fan Replacement: étape 10, image 3 de 3
    • Using the opening tool, carefully go around the edge and loosen the palm-rest assembly, until you can comfortably and easily lift it off.
  11. Toshiba Satellite L505 Laptop Fan Replacement, Hard Drive: étape 11, image 1 de 1
  12. Toshiba Satellite L505 Laptop Fan Replacement: étape 12, image 1 de 3 Toshiba Satellite L505 Laptop Fan Replacement: étape 12, image 2 de 3 Toshiba Satellite L505 Laptop Fan Replacement: étape 12, image 3 de 3
    • Unscrew the screw using a Phillips #1 screwdriver.
    • Lift and remove the cover from the device.
  13. Toshiba Satellite L505 Laptop Fan Replacement: étape 13, image 1 de 3 Toshiba Satellite L505 Laptop Fan Replacement: étape 13, image 2 de 3 Toshiba Satellite L505 Laptop Fan Replacement: étape 13, image 3 de 3
    • Unscrew the circled screw and set it aside.
    • With the laptop oriented with the battery at the top, slide the hard drive component to the left until it clicks.
    • Gently lift up to remove the hard drive from its compartment.
  14. Toshiba Satellite L505 Laptop Fan Replacement, Motherboard: étape 14, image 1 de 2 Toshiba Satellite L505 Laptop Fan Replacement, Motherboard: étape 14, image 2 de 2
    • Once the Motherboard is exposed, unscrew the screws circled in red.
    • Afterwards, gently unplug all the wires connected to the motherboard.
  15. Toshiba Satellite L505 Laptop Fan Replacement: étape 15, image 1 de 2 Toshiba Satellite L505 Laptop Fan Replacement: étape 15, image 2 de 2
    • Once ready to remove the motherboard, carefully pry it away from the bottom first, as to not risk damage to the chassis, since the volume wheel sticks out of the motherboard to the exterior.
  16. Toshiba Satellite L505 Laptop Fan Replacement, Fan: étape 16, image 1 de 2 Toshiba Satellite L505 Laptop Fan Replacement, Fan: étape 16, image 2 de 2
    • Separate the motherboard from the device and flip it over.
4 autres ont terminé cette réparation.
Matias
Membre depuis le 09/26/18
1 028 Réputation
9 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 824
