Aller au contenu principal
Toshiba Satellite L505 Laptop Keyboard Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L505 Laptop Keyboard Replacement, Keyboard: étape 1, image 1 de 3 Toshiba Satellite L505 Laptop Keyboard Replacement, Keyboard: étape 1, image 2 de 3 Toshiba Satellite L505 Laptop Keyboard Replacement, Keyboard: étape 1, image 3 de 3
    • Open the laptop and locate the plastic strip just above the keyboard.
    • With care, slide the prying tool into an end and lift it up until you hear an audible click, meaning it has separated.
    • Slowly slide a finger or the prying tool under and follow the strip to the opposite end, completely detaching the strip.
  2. Toshiba Satellite L505 Laptop Keyboard Replacement: étape 2, image 1 de 2 Toshiba Satellite L505 Laptop Keyboard Replacement: étape 2, image 2 de 2
    • Remove the four screws using the Phillips #1 screwdriver.
  3. Toshiba Satellite L505 Laptop Keyboard Replacement: étape 3, image 1 de 2 Toshiba Satellite L505 Laptop Keyboard Replacement: étape 3, image 2 de 2
    • Gently push the clip back as you lift the top of the keyboard towards you.
    • There is a cable connecting the keyboard to the motherboard so do not lift the keyboard all the way out yet.
  4. Toshiba Satellite L505 Laptop Keyboard Replacement: étape 4, image 1 de 3 Toshiba Satellite L505 Laptop Keyboard Replacement: étape 4, image 2 de 3 Toshiba Satellite L505 Laptop Keyboard Replacement: étape 4, image 3 de 3
    • Gently disconnect the connector strip by pushing the white clips forward.
    • Carefully pull the strip out of its port.
    • Remove the keyboard from the device.
2 autres ont terminé cette réparation.
Matias
Membre depuis le 09/26/18
1 028 Réputation
9 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 1,287
