Introduction
This guide will instruct you on how to remove and replace the battery of your Toshiba Satellite L55W-C5256. You may need to do so if:
- Your device will not hold a charge
- Your device will only power on when plugged into an AC adapter
- Your device will not power on or charge
Before beginning this replacement guide, it is recommended that you use an anti-static work mat and that you ground yourself using an anti-static wrist strap. This helps to protect your device from damage caused by static discharge. If you do not have these materials, you can find an anti-static wrist strap here, and an anti-static work mat here. To learn how to properly use an anti-static wrist strap and an anti-static work mat (recommended), see the guide found here.
Ce dont vous avez besoin
2 autres ont terminé cette réparation.
