Aller au contenu principal
Toshiba Satellite L55W-C5256 Battery Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L55W-C5256 Battery Replacement, Battery: étape 1, image 1 de 1
    • Before beginning this repair, power off your device and unplug all cables and accessory devices.
    • Flip the laptop over so that the model numbers are facing the ceiling.
  2. Toshiba Satellite L55W-C5256 Battery Replacement: étape 2, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the 10 screws that secure the back cover to the device.
  3. Toshiba Satellite L55W-C5256 Battery Replacement: étape 3, image 1 de 1
    • Gently use an iFixit opening tool to separate the back cover from the laptop. Go around all edges until plastic clips are completely free.
    • Ensure all plastic clips have been freed. Attempting to forcefully remove the back cover could result in damage to your device.
  4. Toshiba Satellite L55W-C5256 Battery Replacement: étape 4, image 1 de 1
    • Before touching any component inside your device, ensure you are properly grounded with an anti-static band.
    • Disconnect the battery connector cable from the motherboard.
  5. Toshiba Satellite L55W-C5256 Battery Replacement: étape 5, image 1 de 1
    • Using a Phillip's #00 screwdriver, remove the four 7.0 mm screws that secure the battery to the motherboard.
  6. Toshiba Satellite L55W-C5256 Battery Replacement: étape 6, image 1 de 1
    • Lift the battery from the motherboard.
2 autres ont terminé cette réparation.
Jennifer
Membre depuis le 09/23/19
777 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 14
30 derniers jours : 41
Total : 961
