Introduction
This guide will help you replace a broken motherboard in your laptop. It is a detailed process but this guide will allow you to easily remove and replace your motherboard.
Ce dont vous avez besoin
Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
Use the plastic opening tool to remove the back cover from the laptop.
Evenly press down on the clips on either side of the RAM stick.
To pull out the RAM stick, be sure to align the notches on the RAM stick with the notches in the RAM holder.
Remove the ribbon by flipping up the tabs and using the black tweezers to gently pull the ribbon out from both ends.
Remove the 3 mm Philips head screw that connects the CD drive to motherboard with a Phillips #00 screwdriver.
Using a black tweezer tool, lift the tab holding the ribbon in place and then gently pull it out.
Using the same tweezer tool, again lift the tab holding the wires in place and gently pull them out.
Disconnect all of the ribbons by lifting the tabs and gently pulling them out.
