Aller au contenu principal
Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement, CD/DVD Drive: étape 1, image 1 de 2 Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement, CD/DVD Drive: étape 1, image 2 de 2
    • Unscrew the three 4.6 mm screws holding the panel using a #1 size Phillips head screwdriver. The panel is centered on the bottom of the laptop.
  2. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement: étape 2, image 1 de 1
    • Remove the panel, firmly lifting from the indent. It is recommended that you leave the screws in the panel.
  3. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement: étape 3, image 1 de 1
    • Unscrew the 3.9 mm screw located at the bottom right of the panel.
  4. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement: étape 4, image 1 de 1
    • Use a plastic opening tool to pry the CD drive out of the casing.
  5. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement: étape 5, image 1 de 1
    • Once the CD drive is out far enough to grip, pull the CD drive out to the right.
Torey
Membre depuis le 01/31/13
210 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 7-7, Maness Winter 2013 Membre de l'équipe Cal Poly, Team 7-7, Maness Winter 2013
CPSU-MANESS-W13S7G7
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 2,306
