Aller au contenu principal
Toshiba Satellite L675D-S7016 Disk Drive Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L675D-S7016 Disk Drive Replacement, Back Panel Removal: étape 1, image 1 de 1
    • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
  2. Toshiba Satellite L675D-S7016 Disk Drive Replacement: étape 2, image 1 de 2 Toshiba Satellite L675D-S7016 Disk Drive Replacement: étape 2, image 2 de 2
    • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
    • Work your way around the border of the panel, releasing the rest of the clips.
    • Once all clips are released, lift the cover up and pull towards you.
  3. Toshiba Satellite L675D-S7016 Disk Drive Replacement, Disk Drive: étape 3, image 1 de 1
    • Remove the single 5mm Phillips #1 screw using the screwdriver.
  4. Toshiba Satellite L675D-S7016 Disk Drive Replacement: étape 4, image 1 de 2 Toshiba Satellite L675D-S7016 Disk Drive Replacement: étape 4, image 2 de 2
    • Push the exposed portion of the Disk Drive outwards.
    • The Disk Drive will begin sliding out of its slot. Remove Disk Drive from the laptop by hand.
  5. Toshiba Satellite L675D-S7016 Disk Drive Replacement: étape 5, image 1 de 2 Toshiba Satellite L675D-S7016 Disk Drive Replacement: étape 5, image 2 de 2
    • This step is only necessary if there is a disc stuck inside the drive! If you are replacing the drive and do not need to remove a disc, this can be skipped.
    • On the front of the Disk Drive, below the eject button, insert a pin or paperclip into the hole.
    • Push the pin into hole until the Disk Drive pops out.
Austin Bons
Membre depuis le 09/22/16
1 131 Réputation
8 tutoriels rédigés
Équipe
UC Davis, Team 2-2, Oliver Fall 2016 Membre de l'équipe UC Davis, Team 2-2, Oliver Fall 2016
UCD-OLIVER-F16S2G2
5 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 3
Total : 336
