Aller au contenu principal
Toshiba Satellite L755-S5244 Motherboard Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L755-S5244 Motherboard Replacement, Keyboard: étape 1, image 1 de 2 Toshiba Satellite L755-S5244 Motherboard Replacement, Keyboard: étape 1, image 2 de 2
    • Begin by unscrewing the screw located underneath the battery.
    • Then, unsnap and remove the bar above the keyboard.
  2. Toshiba Satellite L755-S5244 Motherboard Replacement: étape 2, image 1 de 1
    • Unscrew the four 4mm Phillips #0 screws beneath the bar.
  3. Toshiba Satellite L755-S5244 Motherboard Replacement: étape 3, image 1 de 2 Toshiba Satellite L755-S5244 Motherboard Replacement: étape 3, image 2 de 2
    • Pull keyboard up and partially out.
    • Detach conductor ribbon.
    • Slide keyboard out completely.
  4. Toshiba Satellite L755-S5244 Motherboard Replacement, Optical Drive: étape 4, image 1 de 1
    • Before anything start by disconnecting the battery.
  5. Toshiba Satellite L755-S5244 Motherboard Replacement: étape 5, image 1 de 2 Toshiba Satellite L755-S5244 Motherboard Replacement: étape 5, image 2 de 2
    • Next, unscrew the RAM cover and carefully remove it. Then, locate and unscrew the optical drive screw.
  6. Toshiba Satellite L755-S5244 Motherboard Replacement: étape 6, image 1 de 1
    • Carefully remove the optical drive.
  7. Toshiba Satellite L755-S5244 Motherboard Replacement: étape 7, image 1 de 1
    • Finally, detach the mounting bracket from the optical drive in order to attach it to the new optical drive then follow the steps in reverse to reassemble it.
  8. Toshiba Satellite L755-S5244 Motherboard Replacement, Motherboard and Fan: étape 8, image 1 de 1
    • Carefully remove the 2 conductor ribbons.
    • Do not tear the yellow tape covering the upper conductor ribbon if possible.
    • The lower right ribbon may be removed at either the left or right ends by flipping up the black tab.
  9. Toshiba Satellite L755-S5244 Motherboard Replacement: étape 9, image 1 de 1
    • Remove the indicated conduit by gently pulling it away from the motherboard.
  10. Toshiba Satellite L755-S5244 Motherboard Replacement: étape 10, image 1 de 3 Toshiba Satellite L755-S5244 Motherboard Replacement: étape 10, image 2 de 3 Toshiba Satellite L755-S5244 Motherboard Replacement: étape 10, image 3 de 3
    • Remove the 5mm Phillips #0 screw in the middle of the motherboard, and the 4mm Phillips #0 screw on the upper left near the fan.
    • Remove the four 4mm Phillips #0 screws under the edge covering flaps.
    • Carefully lift out the motherboard and fan.
    • To detach the fan, remove the two 2mm Phillips #0 screws.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 9
Total : 1,287
