Aller au contenu principal
Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Battery: étape 1, image 1 de 2 Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Battery: étape 1, image 2 de 2
    • After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
    • This step should always be done before working on your laptop to minimize electrostatic shock.
  2. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Keyboard: étape 2, image 1 de 1
    • Using the plastic opening tool carefully pry the plastic strip that sits at the top of the keyboard.
  3. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: étape 3, image 1 de 1
    • Use the Phillips PH00 to unscrew the four 4mm screws that holds the keyboard in place.
    • Using the plastic opening tool carefully pry your keyboard out without disturbing the cord underneath it.
  4. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: étape 4, image 1 de 1
    • Remaining is the cord that connects the keyboard to the motherboard. Remove this cord after the tabs are pressed in that releases keyboard.
  5. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Optical Disc Drive: étape 5, image 1 de 1
    • Use the screwdiver and the Phillips PH00 to unscrew the three, 4mm screws for the RAM compartment
  6. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: étape 6, image 1 de 2 Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: étape 6, image 2 de 2
    • Use the Phillips PH00 to remove the 4mm screw that holds the ODD.
    • Slide the ODD outward.
  7. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: étape 7, image 1 de 1
    • Remove the two 4mm screws and the plate attached to the ODD.
Michael Griskewicz
Membre depuis le 10/06/16
159 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 2-5, Sullivan Fall 2016 Membre de l'équipe USF Tampa, Team 2-5, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G5
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 11
Total : 330
