Aller au contenu principal
Toshiba Satellite L775D-S7340 Motherboard Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L775D-S7340 Motherboard  Replacement, Battery: étape 1, image 1 de 1
    • Make sure the laptop is unplugged and powered off.
    • Locate the battery latches on the underside of the laptop.
  2. Toshiba Satellite L775D-S7340 Motherboard  Replacement: étape 2, image 1 de 1
    • Slide the right latch to the right until you hear it lock into place.
    • Slide the left latch to the left and hold it.
  3. Toshiba Satellite L775D-S7340 Motherboard  Replacement: étape 3, image 1 de 1
    • Slide the battery out towards you.
  4. Toshiba Satellite L775D-S7340 Motherboard  Replacement, Keyboard: étape 4, image 1 de 1
    • Pry up the thin narrow strip of facing above the keyboard using the opening tool.
  5. Toshiba Satellite L775D-S7340 Motherboard  Replacement: étape 5, image 1 de 1
    • Remove the four screws securing the keyboard using the T4 Torx screwdriver,
  6. Toshiba Satellite L775D-S7340 Motherboard  Replacement: étape 6, image 1 de 2 Toshiba Satellite L775D-S7340 Motherboard  Replacement: étape 6, image 2 de 2
    • Lift the keyboard slowly using the opening tool and lean it toward touchpad.
    • It will still be held by the connector ribbon. Make sure not to pull out the connector ribbon.
  7. Toshiba Satellite L775D-S7340 Motherboard  Replacement: étape 7, image 1 de 1
    • The ribbon is attached by a white clip. Wedge the white clip up carefully using the spudger. This will release the connector ribbon and you can now remove the keyboard.
  8. Toshiba Satellite L775D-S7340 Motherboard  Replacement, Motherboard: étape 8, image 1 de 1
    • Remove the twelve screws from the underside of the laptop using the Phillips #1 screwdriver.
  9. Toshiba Satellite L775D-S7340 Motherboard  Replacement: étape 9, image 1 de 1
    • Remove the three screws from the underside of the laptop using a Phillips #1 screwdriver.
  10. Toshiba Satellite L775D-S7340 Motherboard  Replacement: étape 10, image 1 de 1
    • Remove the two screws from the underside of the laptop, where the battery was located, using the Phillips #1 screwdriver,
  11. Toshiba Satellite L775D-S7340 Motherboard  Replacement: étape 11, image 1 de 1
    • Turn the laptop over and remove the four screws using the Phillips #1 screwdriver.
  12. Toshiba Satellite L775D-S7340 Motherboard  Replacement: étape 12, image 1 de 1
    • Detach the ribbon cable with black clip by carefully using the spudger tool and prying up the black clip gently or gently lift up on the blue tab until the clip releases the ribbon cable.
  13. Toshiba Satellite L775D-S7340 Motherboard  Replacement: étape 13, image 1 de 1
    • Detach the wire connector by using the flat side of the spudger tool to pry the connector apart; this can also be accomplished by gently wiggling the connector until it comes apart.
  14. Toshiba Satellite L775D-S7340 Motherboard  Replacement: étape 14, image 1 de 1
    • Remove the top plastic cover by lifting it from one of the corners. It should come off easily.
  15. Toshiba Satellite L775D-S7340 Motherboard  Replacement: étape 15, image 1 de 1
    • Remove the two screws using the Phillips #1 screwdriver.
  16. Toshiba Satellite L775D-S7340 Motherboard  Replacement: étape 16, image 1 de 1
    • Disconnect the wire ribbon cables by gently lifting up the clips with the spudger or gently lifting on the blue tabs until the clips release the ribbon cables.
  17. Toshiba Satellite L775D-S7340 Motherboard  Replacement: étape 17, image 1 de 1
    • Disconnect the wire connectors by gently prying them apart with the flat end of the spudger. This can also be accomplished by gently wiggling the connector until it comes apart.
  18. Toshiba Satellite L775D-S7340 Motherboard  Replacement: étape 18, image 1 de 1
    • Remove the motherboard.
2 autres ont terminé cette réparation.
Madeline Park
Membre depuis le 09/21/17
441 Réputation
4 tutoriels rédigés
Équipe
Washington State, Team S4-G120, Phelps-Hillen Fall 2017 Membre de l'équipe Washington State, Team S4-G120, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S4G120
6 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 13
Total : 1,461
