Aller au contenu principal
Toshiba Satellite L775D-S7340 Optical Disk Drive Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L775D-S7340 Optical Disk Drive  Replacement, Battery: étape 1, image 1 de 1
    • Make sure the laptop is unplugged and powered off.
    • Locate the battery latches on the underside of the laptop.
  2. Toshiba Satellite L775D-S7340 Optical Disk Drive  Replacement: étape 2, image 1 de 1
    • Slide the right latch to the right until you hear it lock into place.
    • Slide the left latch to the left and hold it.
  3. Toshiba Satellite L775D-S7340 Optical Disk Drive  Replacement: étape 3, image 1 de 1
    • Slide the battery out towards you.
  4. Toshiba Satellite L775D-S7340 Optical Disk Drive  Replacement, Optical Disk Drive: étape 4, image 1 de 1
    • Remove the (mm) screw in between the two white manufacturer’s stickers using the Phillips #1 screwdriver.
  5. Toshiba Satellite L775D-S7340 Optical Disk Drive  Replacement: étape 5, image 1 de 1
    • Gently slide the optical disk drive out of the computer.
Madeline Park
Membre depuis le 09/21/17
441 Réputation
4 tutoriels rédigés
Équipe
Washington State, Team S4-G120, Phelps-Hillen Fall 2017 Membre de l'équipe Washington State, Team S4-G120, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S4G120
6 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 244
