Aller au contenu principal
Toshiba Satellite L855-S5119 Optical Drive Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L855-S5119 Optical Drive Replacement, Back Plate Removal: étape 1, image 1 de 3 Toshiba Satellite L855-S5119 Optical Drive Replacement, Back Plate Removal: étape 1, image 2 de 3 Toshiba Satellite L855-S5119 Optical Drive Replacement, Back Plate Removal: étape 1, image 3 de 3
    • Turn the laptop over to place it top down.
    • Use a Phillips #1 screwdriver to remove the screw holding in the back plate. This screw does not come out of the plate.
    • Lift the back plate off the laptop, exposing the RAM and Hard Disk.
  2. Toshiba Satellite L855-S5119 Optical Drive Replacement, Optical Drive: étape 2, image 1 de 2 Toshiba Satellite L855-S5119 Optical Drive Replacement, Optical Drive: étape 2, image 2 de 2
    • Using a Phillips #0 screwdriver, remove the single 3mm screw.
  3. Toshiba Satellite L855-S5119 Optical Drive Replacement: étape 3, image 1 de 2 Toshiba Satellite L855-S5119 Optical Drive Replacement: étape 3, image 2 de 2
    • Rotate the laptop so that you have access to the optical drive.
    • The optical drive is now only attached by a port in the drive's back. The optical drive can be pulled straight out of its housing.
    • Remove the drive.
Tyler Shafer
Membre depuis le 02/12/18
426 Réputation
3 tutoriels rédigés
Équipe
Washington State, Team S1-G5, Lobnitz Spring 2018 Membre de l'équipe Washington State, Team S1-G5, Lobnitz Spring 2018
WSU-LOBNITZ-S18S1G5
4 membres
18 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 282
