Aller au contenu principal
Toshiba Satellite L855-S5119 Random Access Memory Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L855-S5119 Random Access Memory Replacement, Battery: étape 1, image 1 de 1
    • Turn the laptop face down to expose the back.
    • Locate the battery.
  2. Toshiba Satellite L855-S5119 Random Access Memory Replacement: étape 2, image 1 de 3 Toshiba Satellite L855-S5119 Random Access Memory Replacement: étape 2, image 2 de 3 Toshiba Satellite L855-S5119 Random Access Memory Replacement: étape 2, image 3 de 3
    • Locate the battery latches. The battery latch mechanism can be compared to a door -- The right latch, when pushed right, unlocks the battery, while the left latch, when pushed left, releases the battery, pushing it out from its container.
    • Push the latch on the right to the right to unlock the battery latch locking mechanism.
    • Push the battery latch on the left to the left to unlock the battery.
  3. Toshiba Satellite L855-S5119 Random Access Memory Replacement: étape 3, image 1 de 2 Toshiba Satellite L855-S5119 Random Access Memory Replacement: étape 3, image 2 de 2
    • With the left battery latch pushed left, remove the battery from its port by lifting the battery from the middle of the battery.
    • The battery will come free.
  4. Toshiba Satellite L855-S5119 Random Access Memory Replacement, Back Plate Removal: étape 4, image 1 de 3 Toshiba Satellite L855-S5119 Random Access Memory Replacement, Back Plate Removal: étape 4, image 2 de 3 Toshiba Satellite L855-S5119 Random Access Memory Replacement, Back Plate Removal: étape 4, image 3 de 3
    • Turn the laptop over to place it top down.
    • Use a Phillips #1 screwdriver to remove the screw holding in the back plate. This screw does not come out of the plate.
    • Lift the back plate off the laptop, exposing the RAM and Hard Disk.
  5. Toshiba Satellite L855-S5119 Random Access Memory Replacement, Random Access Memory: étape 5, image 1 de 1
    • Locate the Random Access Memory.
  6. Toshiba Satellite L855-S5119 Random Access Memory Replacement: étape 6, image 1 de 3 Toshiba Satellite L855-S5119 Random Access Memory Replacement: étape 6, image 2 de 3 Toshiba Satellite L855-S5119 Random Access Memory Replacement: étape 6, image 3 de 3
    • Pull back the two retention clips holding the RAM in place allowing it to pop up.
    • Remove the RAM by pulling it from the SO-DIMM slot.
2 autres ont terminé cette réparation.
Cody Brannen
Membre depuis le 02/12/18
213 Réputation
1 tutoriel rédigé
Équipe
Washington State, Team S1-G5, Lobnitz Spring 2018 Membre de l'équipe Washington State, Team S1-G5, Lobnitz Spring 2018
WSU-LOBNITZ-S18S1G5
4 membres
18 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 13
Total : 456
