Aller au contenu principal
Introduction
This guide describes how to replace the battery of the Toshiba Satellite M45 laptop.
  1. If the device is still running, please turn the computer off properly and then disconnect the power supply from the power supply port in the back of the computer. Remove battery before beginning any work to reduce electrical shock and to prevent damage to the electrical components. Locate and slide the 2-battery locks to disconnect the battery.
    • If the device is still running, please turn the computer off properly and then disconnect the power supply from the power supply port in the back of the computer.
    • Remove battery before beginning any work to reduce electrical shock and to prevent damage to the electrical components.
    • Locate and slide the 2-battery locks to disconnect the battery.
    • Remove the battery by sliding it out away from the computer (horizontal with the casing).
Ligne d'arrivée
Stephen
Membre depuis le 20/04/2010
352 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 10-42, Garner Spring 2010 Membre de l'équipe Cal Poly, Team 10-42, Garner Spring 2010
CPSU-GARNER-S10S10G42
5 membres
10 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 3,969
