Aller au contenu principal
Introduction
This guide will illustrate how to replace your optical drive.
Pièces
Aucune pièce spécifiée.
  1. Remove the ODD screw with a #1 Phillips head screwdriver as indicated in the picture. Using a flat edge tool, pry it the drive out of it slot from the side of the casing. You can then use your hands to continue pulling the rest the way out of its slot. Using a flat edge tool, pry it the drive out of it slot from the side of the casing. You can then use your hands to continue pulling the rest the way out of its slot.
    • Remove the ODD screw with a #1 Phillips head screwdriver as indicated in the picture.
    • Using a flat edge tool, pry it the drive out of it slot from the side of the casing. You can then use your hands to continue pulling the rest the way out of its slot.
  2. Kits pour Apple Watch
    Réparer l'écran et la batterie n'a jamais été aussi facile.
    Acheter maintenant
    Acheter maintenant
Nick
Membre depuis le 16/04/2010
127 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 10-42, Garner Spring 2010 Membre de l'équipe Cal Poly, Team 10-42, Garner Spring 2010
CPSU-GARNER-S10S10G42
5 membres
10 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 3,241
