Aller au contenu principal
Toshiba Satellite M55-S135 Keyboard Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite M55-S135 Keyboard Replacement, Keyboard: étape 1, image 1 de 1
    • Start with the laptop open and the keyboard facing you.
    • Tilt the screen away from you to reduce the risk of damaging it as you remove the keyboard.
  2. Toshiba Satellite M55-S135 Keyboard Replacement: étape 2, image 1 de 2 Toshiba Satellite M55-S135 Keyboard Replacement: étape 2, image 2 de 2
    • Locate the vertical seam between the speakers and the top row of keys on the keyboard.
    • Insert the tip of a nylon spudger into the seam and slowly pry up the panel.
    • Be sure to gently pry the panel to avoid damaging it or the laptop.
  3. Toshiba Satellite M55-S135 Keyboard Replacement: étape 3, image 1 de 2 Toshiba Satellite M55-S135 Keyboard Replacement: étape 3, image 2 de 2
    • Remove both 6.72mm screws from the upper left and right of the keyboard using the Phillips #00 screwdriver.
  4. Toshiba Satellite M55-S135 Keyboard Replacement: étape 4, image 1 de 1
    • Use the nylon spudger to pry up the keyboard. Start with one side and then the other.
    • Be sure to pry gently with the screwdriver to avoid damaging the keyboard and keys.
  5. Toshiba Satellite M55-S135 Keyboard Replacement: étape 5, image 1 de 1
    • Gently lift the keyboard to reveal the keyboard cable located near the mouse pad.
    • Disconnect the keyboard cable.
    • Be sure to disconnect the cable before removing the keyboard to avoid damaging it.
klismann Evora
Membre depuis le 03/12/14
109 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 5-7, Cichon Spring 2014 Membre de l'équipe UMass Dartmouth, Team 5-7, Cichon Spring 2014
UMASSD-CICHON-S14S5G7
4 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 12
Total : 706
