Aller au contenu principal
Toshiba Satellite M55-S135 Optical Drive Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite M55-S135 Optical Drive Replacement, RAM: étape 1, image 1 de 1
    • Orient the laptop so that it is closed, faced down and has the battery facing away from you.
    • Use the Phillips 00 screwdriver to remove the 7.50mm screw from the panel.
  2. Toshiba Satellite M55-S135 Optical Drive Replacement: étape 2, image 1 de 1
    • Carefully remove the cover to reveal the RAM compartment.
  3. Toshiba Satellite M55-S135 Optical Drive Replacement: étape 3, image 1 de 2 Toshiba Satellite M55-S135 Optical Drive Replacement: étape 3, image 2 de 2
    • Rotate the laptop 90 degrees clockwise.
    • Pull back the two silver clips that hold the RAM in place.
    • Gently pull the RAM out of the slot and lift up to remove the RAM from the laptop.
  4. Toshiba Satellite M55-S135 Optical Drive Replacement, Optical Drive: étape 4, image 1 de 1
    • Use the Phillips #00 screwdriver to remove the 6.50mm screw holding the gray metal bracket in place.
  5. Toshiba Satellite M55-S135 Optical Drive Replacement: étape 5, image 1 de 1
    • Turn the laptop 180 degrees then tilt the near side up.
    • Push the back side of the optical drive out of the laptop using the plastic opening tool.
  6. Toshiba Satellite M55-S135 Optical Drive Replacement: étape 6, image 1 de 1
    • Pull the optical drive out of the laptop using your fingers.
  7. Toshiba Satellite M55-S135 Optical Drive Replacement: étape 7, image 1 de 1
    • Using the Phillips 00 screwdriver, unscrew the two 2.50mm screws that connect the metal bracket to the optical drive.
    • Remove the bracket from optical drive.
Yuheng Huang
Membre depuis le 01/28/13
13 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 7-11, Maness Winter 2013 Membre de l'équipe Cal Poly, Team 7-11, Maness Winter 2013
CPSU-MANESS-W13S7G11
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 655
