Introduction
This is a replacement guide for the Toshiba Satellite P105-S6147 cooling fan. This part is responsible for preventing the device from overheating. Refer to this troubleshooting guide before replacing the cooling fan. Replace this part if the device continues to overheat after troubleshooting.
All the tools you will need in this guide can be found in the iFixit Pro Toolkit. We suggest you perform this replacement on a large, level workspace where you can avoid knocking small parts onto the floor. Label any small parts so you know where to put them when reassembling the laptop.
Consult the Toshiba Satellite P105-S6147 Device Page for further questions.
Ce dont vous avez besoin
Begin by placing the laptop face down on a flat surface.
Slide the lock switch on the battery to the unlocked position.
Slide the release lever on the battery towards the lock switch. The battery should now rotate out of its dock in the laptop.
Outil utilisé dans cette étape :Tweezers$4.99
Use the precision tweezers to remove the metal cover off the top of the cooling fan. It should "pop" off with little effort.
Flip over the motherboard.
The cooling fan is now located in the upper left-hand corner of the motherboard.
