Aller au contenu principal
Toshiba Satellite P105-S6147 RAM Replacement
  1. Toshiba Satellite P105-S6147 RAM Replacement, RAM: étape 1, image 1 de 1
    • Begin with the laptop laying down on a flat surface, with the bottom facing up.
  2. Toshiba Satellite P105-S6147 RAM Replacement: étape 2, image 1 de 3 Toshiba Satellite P105-S6147 RAM Replacement: étape 2, image 2 de 3 Toshiba Satellite P105-S6147 RAM Replacement: étape 2, image 3 de 3
    • Remove the battery from the device.
    • The battery is located in the bottom, left hand corner of the device.
    • Slide the lock switch to the unlocked position.
    • Slide the release lever towards the unlock switch. The battery should now rotate out of its dock in the laptop.
  3. Toshiba Satellite P105-S6147 RAM Replacement: étape 3, image 1 de 2 Toshiba Satellite P105-S6147 RAM Replacement: étape 3, image 2 de 2
    • Open the casing directly above the battery.
    • Use a Phillips #0 screwdriver to remove two 4 mm screws located at the top of the casing.
    • Once the cover is removed the RAM sticks will be visible.
  4. Toshiba Satellite P105-S6147 RAM Replacement: étape 4, image 1 de 2 Toshiba Satellite P105-S6147 RAM Replacement: étape 4, image 2 de 2
    • Use a nylon spudger to disconnect the tabs from the RAM. The tabs are located on either side of the RAM.
    • Apply light, outward force to the tabs.
  5. Toshiba Satellite P105-S6147 RAM Replacement: étape 5, image 1 de 3 Toshiba Satellite P105-S6147 RAM Replacement: étape 5, image 2 de 3 Toshiba Satellite P105-S6147 RAM Replacement: étape 5, image 3 de 3
    • Use the iFixit opening tool to apply light pressure to the bottom of the upper RAM stick.
    • The RAM stick should come loose and be removable by hand.
    • Repeat the previous steps to remove the lower RAM stick.
Benjamin Wilkinson
Membre depuis le 09/21/18
905 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 13
Total : 220
