Introduction
You can use this guide to replace the speakers of your Toshiba laptop if they are no longer working. This guide will take you through the steps to access the speakers in order to replace them with working ones.
Outils
Pièces
Aucune pièce spécifiée.
Flip the laptop over so the bottom is facing upward and the battery is on top.
Slide the tab below the battery to the left.
Place the head of a plastic opening tool underneath the plastic strip lining the top of the keyboard, right above the "PGUP" button.
Next, pull the strip up using a plastic opening tool with a light force, until it pops off.
Lightly lift up on the keyboard from one of its top corners and pull it towards the screen so you can safely remove the ribbon cable.
At the base of the ribbon cable, there is a tiny tab that runs across the width of the connector. Flip it up. You can now pull the ribbon cable free with no resistance towards the monitor.
With the cable unplugged, the keyboard can be lifted away from the laptop.
Unscrew the 4mm Phillips #1 screw holding the hard drive cover on.
Place one finger underneath the tab of the hard drive cover and lift it up with medium force to take it off.
Use a plastic opening tool to loosen the top panel by placing the tool underneath the panel at several points and then lifting upwards with a medium force. You will know it is loose if it makes a loud clicking noise.
Place your fingers on the side of the panel closest to the monitor. Lift up on that side of the panel with a large amount of force in order to pry it off.
Remove the 2 silver 6mm Phillips #1 screws from the middle of where the keyboard was removed
Remove the four 4mm Phillips #1 screws from the bottom of the laptop.
Two screws are located inside the disk drive compartment. (You may need to poke out the hole covers above the disk drive compartment in order to easily unscrew the two screws beneath)
The other two screws are located at the top of the battery compartment.
Once you have lifted the panel up enough on the right side, you can insert your fingers or a spudger between the top and bottom panels.
Then gently move your fingers or spudger along the bottom and sides of the laptop, loosening the panel even more until it comes completely loose.
Once the top panel is completely loose lift the top panel up slightly so that the mousepad wire is visible underneath it. Unplug the mousepad wire from the bottom of the laptop.
3 autre(s) ont terminé cette réparation.
