Aller au contenu principal
Toshiba Satellite P205D-S8804 Screen Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite P205D-S8804 Screen Replacement, Screen: étape 1, image 1 de 1
    • With the screen on a flat surface, remove the screws in each corner of the screen. There will be 4 in total.
    • Note: The screws for the screen may be hidden under rubber pad at the top of the screen so they will have to be removed.
  2. Toshiba Satellite P205D-S8804 Screen Replacement: étape 2, image 1 de 1
    • Using a metal spudger wedge open the front and back cover of the screen.
    • Take care to not damage the camera in the process.
  3. Toshiba Satellite P205D-S8804 Screen Replacement: étape 3, image 1 de 2 Toshiba Satellite P205D-S8804 Screen Replacement: étape 3, image 2 de 2
    • After the front cover is removed remove the two screws at the very bottom of the screen.
    • This will give you access to the screws running along the side of the screen.
  4. Toshiba Satellite P205D-S8804 Screen Replacement: étape 4, image 1 de 1
    • Remove the four screws on the each side of the screen. There will be eight in total.
    • We recommend starting from the bottom and working upward.
  5. Toshiba Satellite P205D-S8804 Screen Replacement: étape 5, image 1 de 1
    • Lay the screen flat on the keyboard so they the back panel can be accessed.
    • Remove all the tape on the video cable that connects the screen to the computer.
  6. Toshiba Satellite P205D-S8804 Screen Replacement: étape 6, image 1 de 1
    • Remove the video cable from the screen.
    • After the video cable is removed the screen is free and can be removed from the computer.
Caroline Camp
Membre depuis le 01/30/17
1 Réputation
3 tutoriels rédigés
Équipe
Baylor, Team 3-2, Whitney Spring 2017 Membre de l'équipe Baylor, Team 3-2, Whitney Spring 2017
BU-WHITNEY-S17S3G2
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 113
