Aller au contenu principal
Toshiba Satellite P50W-C Battery Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite P50W-C Battery Replacement, Back Cover: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    • Turn the laptop off, unplug the AC adapter, and any other auxiliary components.
    • Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
  2. Toshiba Satellite P50W-C Battery Replacement: étape 2, image 1 de 1
    • Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
  3. Toshiba Satellite P50W-C Battery Replacement: étape 3, image 1 de 2 Toshiba Satellite P50W-C Battery Replacement: étape 3, image 2 de 2
    • Use the spudger to pry under the back cover until it pops off.
  4. Toshiba Satellite P50W-C Battery Replacement, Battery: étape 4, image 1 de 1
    • Unscrew the four 5 mm JIS #1 head screws holding the battery to the device and gently remove the battery.
  5. Toshiba Satellite P50W-C Battery Replacement: étape 5, image 1 de 2 Toshiba Satellite P50W-C Battery Replacement: étape 5, image 2 de 2
    • Disconnect the battery from the motherboard by gently pulling out the black connector.
Lawrence Lozada
Membre depuis le 09/25/17
246 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S3-G2, Cannon Fall 2017 Membre de l'équipe USF Tampa, Team S3-G2, Cannon Fall 2017
USFT-CANNON-F17S3G2
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 1,019
