Aller au contenu principal
Toshiba Satellite P55W-C5316 RAM Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite P55W-C5316 RAM Replacement, Back Panel: étape 1, image 1 de 2 Toshiba Satellite P55W-C5316 RAM Replacement, Back Panel: étape 1, image 2 de 2
    • To prevent injury, ensure the laptop is powered off before starting your work.
    • Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
  2. Toshiba Satellite P55W-C5316 RAM Replacement: étape 2, image 1 de 3 Toshiba Satellite P55W-C5316 RAM Replacement: étape 2, image 2 de 3 Toshiba Satellite P55W-C5316 RAM Replacement: étape 2, image 3 de 3
    • Be careful to not crack the panel where the USB and power cord ports are.
    • Insert the opening tool in between the back panel and the laptop to pry it open.
    • The back panel is magnetically attached at the front of the laptop so you may have to move the opening tool along the length of the panel.
    • Lift the panel from the front off of the laptop.
  3. Toshiba Satellite P55W-C5316 RAM Replacement, Battery: étape 3, image 1 de 3 Toshiba Satellite P55W-C5316 RAM Replacement, Battery: étape 3, image 2 de 3 Toshiba Satellite P55W-C5316 RAM Replacement, Battery: étape 3, image 3 de 3
    • The battery is located in the bottom right corner of the laptop.
    • Remove the four .5mm Phillips head screws on the battery using the PH1 screwdriver.
  4. Toshiba Satellite P55W-C5316 RAM Replacement: étape 4, image 1 de 2 Toshiba Satellite P55W-C5316 RAM Replacement: étape 4, image 2 de 2
    • Do not tug on the cord or battery. Instead, pull evenly on the connector.
    • Lift the battery and gently pull out the bundled cable connector.
  5. Toshiba Satellite P55W-C5316 RAM Replacement, RAM: étape 5, image 1 de 3 Toshiba Satellite P55W-C5316 RAM Replacement, RAM: étape 5, image 2 de 3 Toshiba Satellite P55W-C5316 RAM Replacement, RAM: étape 5, image 3 de 3
    • Lift up the flap to expose the RAM chip.
    • Un-clip the RAM by pulling the metal clips away from the chip on both sides.
    • Lift the RAM up from the laptop and pull it away from the connector.
Alec Bonnell
Membre depuis le 10/18/17
497 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G2, Bailey Fall 2017 Membre de l'équipe UMass Dartmouth, Team S3-G2, Bailey Fall 2017
UMASSD-BAILEY-F17S3G2
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 596
