Introduction
Use this guide to remove the Toshiba Satellite P55t-A5116 Power Jack.
Ce dont vous avez besoin
Use the #PH0 screw head, remove 4 (5.7mm) screws.
Unplug the battery's 10 pin connector and gently lift the battery out of the laptop.
Using the #PH0 screw head, remove 2 (5.7 mm) screws.
Remove metal plate.
Using the #PH0 screw head remove 1 (5.7mm) screw and 1 (4.15mm) screw.
2 autres ont terminé cette réparation.
