Aller au contenu principal
Toshiba Satellite P55t-A5116 RAM Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite P55t-A5116 RAM  Replacement, Back Casing: étape 1, image 1 de 2 Toshiba Satellite P55t-A5116 RAM  Replacement, Back Casing: étape 1, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Close laptop and turn it upside down
    • Remove the 14 circular rubber covers with tweezers along with one smaller more cylindrical rubber cover.
  2. Toshiba Satellite P55t-A5116 RAM  Replacement: étape 2, image 1 de 2 Toshiba Satellite P55t-A5116 RAM  Replacement: étape 2, image 2 de 2
    • Using the #PH0 screw head, remove 14 (5.7 mm) screws from the back casing.
  3. Toshiba Satellite P55t-A5116 RAM  Replacement: étape 3, image 1 de 3 Toshiba Satellite P55t-A5116 RAM  Replacement: étape 3, image 2 de 3 Toshiba Satellite P55t-A5116 RAM  Replacement: étape 3, image 3 de 3
    • Gently pry off the bottom case with the plastic opening tools.
    • Find the seam between the back case and the rest of the laptop casing.
  4. Toshiba Satellite P55t-A5116 RAM  Replacement, RAM: étape 4, image 1 de 3 Toshiba Satellite P55t-A5116 RAM  Replacement, RAM: étape 4, image 2 de 3 Toshiba Satellite P55t-A5116 RAM  Replacement, RAM: étape 4, image 3 de 3
    • Locate the RAM cover on the back of the Laptop.
    • Using the #PH0 screw head, remove 1 (5.7mm) screw.
    • Use the plastic opening tool to remove the RAM cover.
  5. Toshiba Satellite P55t-A5116 RAM  Replacement: étape 5, image 1 de 3 Toshiba Satellite P55t-A5116 RAM  Replacement: étape 5, image 2 de 3 Toshiba Satellite P55t-A5116 RAM  Replacement: étape 5, image 3 de 3
    • Pull out the latches on either side.
    • The RAM should pop up.
    • Remove the RAM.
    • Repeat for other side.
Brittany Castillo
Membre depuis le 01/19/17
878 Réputation
5 tutoriels rédigés
Un commentaire
I’m confused… it only seems like Step 4 and Step 5 are necessary. Does the battery need to be removed before replacing the RAM? If that’s why Steps 1-3 are there, there’s a lot of steps/information missing. It just goes from “take off the bottom case” to “remove the RAM cover of intact laptop”.
Douggy - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 14
Total : 557
