Aller au contenu principal
Toshiba Satellite P75-A7100 Fan Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite P75-A7100 Fan Replacement, Battery: étape 1, image 1 de 1
    • Slide the tabs apart from each other.
  2. Toshiba Satellite P75-A7100 Fan Replacement: étape 2, image 1 de 2 Toshiba Satellite P75-A7100 Fan Replacement: étape 2, image 2 de 2
    • Lift the battery upwards and remove it from the device.
  3. Toshiba Satellite P75-A7100 Fan Replacement, Wi-Fi Adapter: étape 3, image 1 de 2 Toshiba Satellite P75-A7100 Fan Replacement, Wi-Fi Adapter: étape 3, image 2 de 2
    • Using a Phillips #1 screwdriver, remove the screw from the back cover.
    • Remove the back cover from the device.
  4. Toshiba Satellite P75-A7100 Fan Replacement: étape 4, image 1 de 3 Toshiba Satellite P75-A7100 Fan Replacement: étape 4, image 2 de 3 Toshiba Satellite P75-A7100 Fan Replacement: étape 4, image 3 de 3
    • Remove the optical drive from the device.
  5. Toshiba Satellite P75-A7100 Fan Replacement: étape 5, image 1 de 2 Toshiba Satellite P75-A7100 Fan Replacement: étape 5, image 2 de 2
    • Using a Phillips #1 screwdriver, unscrew the remaining screws that are visible on the laptop.
    • Remove the back cover from your device.
  6. Toshiba Satellite P75-A7100 Fan Replacement: étape 6, image 1 de 3 Toshiba Satellite P75-A7100 Fan Replacement: étape 6, image 2 de 3 Toshiba Satellite P75-A7100 Fan Replacement: étape 6, image 3 de 3
    • Using a Phillips #1 screwdriver, remove the screw connecting the Wi-Fi adapter to the motherboard.
    • Remove the Wi-Fi adapter from the device.
  7. Toshiba Satellite P75-A7100 Fan Replacement, Fan: étape 7, image 1 de 2 Toshiba Satellite P75-A7100 Fan Replacement, Fan: étape 7, image 2 de 2
    • Using a Phillips #1 screwdriver, unscrew the 6 remaining screws attached to the fan.
    • Unplug the connector connecting the fan to the motherboard.
    • Remove the fan from the device.
2 autres ont terminé cette réparation.
Un commentaire
How do you remove and replace the fan from from/to the heatsink? Mine is secured with a metallic tape that is not sticky once removed.
Bruce - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 10
Total : 2,364
