Aller au contenu principal
Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement, Battery: étape 1, image 1 de 1
    • Slide the tabs apart from each other.
  2. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: étape 2, image 1 de 2 Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: étape 2, image 2 de 2
    • Lift the battery upwards and remove it from the device.
  3. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement, Wi-Fi Adapter: étape 3, image 1 de 2 Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement, Wi-Fi Adapter: étape 3, image 2 de 2
    • Using a Phillips #1 screwdriver, remove the screw from the back cover.
    • Remove the back cover from the device.
  4. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: étape 4, image 1 de 3 Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: étape 4, image 2 de 3 Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: étape 4, image 3 de 3
    • Remove the optical drive from the device.
  5. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: étape 5, image 1 de 2 Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: étape 5, image 2 de 2
    • Using a Phillips #1 screwdriver, unscrew the remaining screws that are visible on the laptop.
    • Remove the back cover from your device.
  6. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: étape 6, image 1 de 3 Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: étape 6, image 2 de 3 Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: étape 6, image 3 de 3
    • Using a Phillips #1 screwdriver, remove the screw connecting the Wi-Fi adapter to the motherboard.
    • Remove the Wi-Fi adapter from the device.
Brandon Cole
Membre depuis le 01/17/18
323 Réputation
1 tutoriel rédigé
Un commentaire
¿Como reemplazo el cable blanco?, esta cortado.
Henry Rivera - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 1,111
