Aller au contenu principal
Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement, Battery: étape 1, image 1 de 1
    • First flip the device over so that the back side is facing upwards
  2. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: étape 2, image 1 de 1
    • Push the two sliders toward the edge of the laptop.
    • Remove the battery.
  3. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement, Display Assembly: étape 3, image 1 de 1
    • Open the lid.
  4. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: étape 4, image 1 de 3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: étape 4, image 2 de 3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: étape 4, image 3 de 3
    • Remove the four screw covers in each of the four corners of the screen.
  5. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: étape 5, image 1 de 3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: étape 5, image 2 de 3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: étape 5, image 3 de 3
    • Remove the 4 screws in each of the 4 corners.
  6. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: étape 6, image 1 de 3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: étape 6, image 2 de 3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: étape 6, image 3 de 3
    • Take your prying tool and proceed to pry the screen cover off and set to the side.
  7. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: étape 7, image 1 de 1
    • Disconnect the wire from the camera and the backside of the display assembly.
  8. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: étape 8, image 1 de 3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: étape 8, image 2 de 3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: étape 8, image 3 de 3
    • Remove the 6 screws holding the display assembly and holding brackets together.
Jacob Volcke
Membre depuis le 09/22/22
665 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 1
Total : 100
