Aller au contenu principal
Toshiba Satellite P855-S5312 Disk Drive Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite P855-S5312 Disk Drive Replacement, Battery: étape 1, image 1 de 3 Toshiba Satellite P855-S5312 Disk Drive Replacement, Battery: étape 1, image 2 de 3 Toshiba Satellite P855-S5312 Disk Drive Replacement, Battery: étape 1, image 3 de 3
    • Turn laptop upside down with the spine facing towards you and locate the two tabs on the top of the back panel.
    • Move the sliders to the left and right to release the tabs holding the battery in.
    • While the tabs are pushed outwards, remove the battery from the device.
  2. Toshiba Satellite P855-S5312 Disk Drive Replacement, Disk Drive: étape 2, image 1 de 2 Toshiba Satellite P855-S5312 Disk Drive Replacement, Disk Drive: étape 2, image 2 de 2
    • Once laptop is turned over with the spine facing you, locate the large L shape panel.
    • Using a Philips #0 screwdriver unscrew the 1.5mm screw towards the bottom of the laptop.
  3. Toshiba Satellite P855-S5312 Disk Drive Replacement: étape 3, image 1 de 2 Toshiba Satellite P855-S5312 Disk Drive Replacement: étape 3, image 2 de 2
    • Open the motherboard access cover.
  4. Toshiba Satellite P855-S5312 Disk Drive Replacement: étape 4, image 1 de 2 Toshiba Satellite P855-S5312 Disk Drive Replacement: étape 4, image 2 de 2
    • Using a Philips #0 screwdriver, unscrew the 1.5mm screw located near the left edge of the opening near the mother board.
  5. Toshiba Satellite P855-S5312 Disk Drive Replacement: étape 5, image 1 de 2 Toshiba Satellite P855-S5312 Disk Drive Replacement: étape 5, image 2 de 2
    • Gently pull the entire disk drive assembly out.
  6. Toshiba Satellite P855-S5312 Disk Drive Replacement: étape 6, image 1 de 3 Toshiba Satellite P855-S5312 Disk Drive Replacement: étape 6, image 2 de 3 Toshiba Satellite P855-S5312 Disk Drive Replacement: étape 6, image 3 de 3
    • Flip your device over and rotate the side of the optical drive over to you.
    • Unclip the clips on the side of the automatic release.
    • Use a paper clip or small needle tool to insert in the manual release located on the right of the automatic release button.
    • Once released slide the aluminum case out.
Bishop Clark
Membre depuis le 10/02/17
225 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S10-G2, Thompson Fall 2017 Membre de l'équipe USF Tampa, Team S10-G2, Thompson Fall 2017
USFT-THOMPSON-F17S10G2
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 3
Total : 516
