Aller au contenu principal
Toshiba Satellite P855-S5312 Fan Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite P855-S5312 Fan Replacement, Battery: étape 1, image 1 de 3 Toshiba Satellite P855-S5312 Fan Replacement, Battery: étape 1, image 2 de 3 Toshiba Satellite P855-S5312 Fan Replacement, Battery: étape 1, image 3 de 3
    • Turn laptop upside down with the spine facing towards you and locate the two tabs on the top of the back panel.
    • Move the sliders to the left and right to release the tabs holding the battery in.
    • While the tabs are pushed outwards, remove the battery from the device.
  2. Toshiba Satellite P855-S5312 Fan Replacement, Keyboard: étape 2, image 1 de 3 Toshiba Satellite P855-S5312 Fan Replacement, Keyboard: étape 2, image 2 de 3 Toshiba Satellite P855-S5312 Fan Replacement, Keyboard: étape 2, image 3 de 3
    • Using plastic spudger to pry up the edges of the keyboard and lift it towards the screen.
    • Unplug the ZIF connector ribbon using the plastic spudger by gently prying the edges of the plug.
    • Remove the keyboard from the device.
  3. Toshiba Satellite P855-S5312 Fan Replacement, Fan: étape 3, image 1 de 3 Toshiba Satellite P855-S5312 Fan Replacement, Fan: étape 3, image 2 de 3 Toshiba Satellite P855-S5312 Fan Replacement, Fan: étape 3, image 3 de 3
    • Unscrew the one 1.5mm screw using a Philips #0 screwdriver holding the L shape panel.
    • Pry up the panel to gain access to hidden screws.
  4. Toshiba Satellite P855-S5312 Fan Replacement: étape 4, image 1 de 2 Toshiba Satellite P855-S5312 Fan Replacement: étape 4, image 2 de 2
    • Remove the fourteen (14) screws using a Philips #0 screwdriver for the 1.5mm screws on the underside of casing.
  5. Toshiba Satellite P855-S5312 Fan Replacement: étape 5, image 1 de 3 Toshiba Satellite P855-S5312 Fan Replacement: étape 5, image 2 de 3 Toshiba Satellite P855-S5312 Fan Replacement: étape 5, image 3 de 3
    • Unscrew the nine 1.5mm screws using a Philips #0 screwdriver under the keyboard with the F6 printed next to them.
    • Unplug the three no-fuss ribbon cable connector cables by gently pulling on them away from you towards the keyboard.
  6. Toshiba Satellite P855-S5312 Fan Replacement: étape 6, image 1 de 2 Toshiba Satellite P855-S5312 Fan Replacement: étape 6, image 2 de 2
    • Pry apart the casing with the plastic opening tool.
    • Removing the cover under keyboard.
  7. Toshiba Satellite P855-S5312 Fan Replacement: étape 7, image 1 de 3 Toshiba Satellite P855-S5312 Fan Replacement: étape 7, image 2 de 3 Toshiba Satellite P855-S5312 Fan Replacement: étape 7, image 3 de 3
    • Unplug the single no-fuss cable connector using the plastic opening tool pushing the edges towards the fan.
    • Unscrew the two 1.5mm screws using a Philips #0 screwdriver by the head mounting holding down the fan.
    • Pull the fan up and remove it from the device.
Dalton
Membre depuis le 10/02/17
215 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S10-G2, Thompson Fall 2017 Membre de l'équipe USF Tampa, Team S10-G2, Thompson Fall 2017
USFT-THOMPSON-F17S10G2
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 11
Total : 558
