Introduction
Guide is to replace the hinge of the Toshiba Satellite P855-S5312 . Reasons for replacement would be if the screen will not stay in place being to flimsy because hinge. Tools required for guide are phillips size 0 screwdriver.
Ce dont vous avez besoin
Unscrew the one 1.5mm screw using a Philips #0 screwdriver holding the L shape panel.
Pry up the panel to gain access to hidden screws.
Remove the three screws on the sides of the screen using the Philips #0 screwdriver.
Once unscrewed, pull the frame off along with the hinge.
