Aller au contenu principal
Toshiba Satellite R15-S829 Disk Drive Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite R15-S829 Disk Drive Replacement, Battery Replacement: étape 1, image 1 de 1
    • Unplug the charging cable from the laptop.
    • Turn off the laptop.
    • Turn the laptop over and locate the battery.
  2. Toshiba Satellite R15-S829 Disk Drive Replacement: étape 2, image 1 de 3 Toshiba Satellite R15-S829 Disk Drive Replacement: étape 2, image 2 de 3 Toshiba Satellite R15-S829 Disk Drive Replacement: étape 2, image 3 de 3
    • Push the small switch near the corner of the laptop to the unlocked position.
    • Push the bigger switch in the direction of the icon and pull the battery away from the laptop.
  3. Toshiba Satellite R15-S829 Disk Drive Replacement, Disk Drive Replacement: étape 3, image 1 de 2 Toshiba Satellite R15-S829 Disk Drive Replacement, Disk Drive Replacement: étape 3, image 2 de 2
    • Locate the disk drive on the side of the laptop.
  4. Toshiba Satellite R15-S829 Disk Drive Replacement: étape 4, image 1 de 1
    • Locate the indent on disk drive on the backside of the computer.
  5. Toshiba Satellite R15-S829 Disk Drive Replacement: étape 5, image 1 de 2 Toshiba Satellite R15-S829 Disk Drive Replacement: étape 5, image 2 de 2
    • Use your hand to remove the disk drive by pulling outward.
  6. Toshiba Satellite R15-S829 Disk Drive Replacement: étape 6, image 1 de 3 Toshiba Satellite R15-S829 Disk Drive Replacement: étape 6, image 2 de 3 Toshiba Satellite R15-S829 Disk Drive Replacement: étape 6, image 3 de 3
    • Push the end of a paperclip into the small hole on the disk drive to open it if there is a disk that is stuck in the drive.
Justin Slater
Membre depuis le 10/20/16
128 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 5-8, Martin Fall 2016 Membre de l'équipe UMass Dartmouth, Team 5-8, Martin Fall 2016
UMASSD-MARTIN-F16S5G8
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 167
