Aller au contenu principal
Toshiba Satellite R15-S829 Hard Drive Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite R15-S829 Hard Drive Replacement, Battery Replacement: étape 1, image 1 de 1
    • Unplug the charging cable from the laptop.
    • Turn off the laptop.
    • Turn the laptop over and locate the battery.
  2. Toshiba Satellite R15-S829 Hard Drive Replacement: étape 2, image 1 de 3 Toshiba Satellite R15-S829 Hard Drive Replacement: étape 2, image 2 de 3 Toshiba Satellite R15-S829 Hard Drive Replacement: étape 2, image 3 de 3
    • Push the small switch near the corner of the laptop to the unlocked position.
    • Push the bigger switch in the direction of the icon and pull the battery away from the laptop.
  3. Toshiba Satellite R15-S829 Hard Drive Replacement, Hard Drive Replacement: étape 3, image 1 de 1
    • First, begin by locating the spot of the cover of the hard drive located on the bottom of the laptop.
  4. Toshiba Satellite R15-S829 Hard Drive Replacement: étape 4, image 1 de 1
    • Remove the screw of the cover.
  5. Toshiba Satellite R15-S829 Hard Drive Replacement: étape 5, image 1 de 2 Toshiba Satellite R15-S829 Hard Drive Replacement: étape 5, image 2 de 2
    • Locate the indent where the hard drive can be removed. Remove the cover.
  6. Toshiba Satellite R15-S829 Hard Drive Replacement: étape 6, image 1 de 2 Toshiba Satellite R15-S829 Hard Drive Replacement: étape 6, image 2 de 2
    • Remove the hard drive using your hand.
  7. Toshiba Satellite R15-S829 Hard Drive Replacement: étape 7, image 1 de 3 Toshiba Satellite R15-S829 Hard Drive Replacement: étape 7, image 2 de 3 Toshiba Satellite R15-S829 Hard Drive Replacement: étape 7, image 3 de 3
    • Now remove the power ribbon from the hard drive.
  8. Toshiba Satellite R15-S829 Hard Drive Replacement: étape 8, image 1 de 1
    • Locate the screws on each side of the encasing of the hard drive.
  9. Toshiba Satellite R15-S829 Hard Drive Replacement: étape 9, image 1 de 2 Toshiba Satellite R15-S829 Hard Drive Replacement: étape 9, image 2 de 2
    • Use your Phillips screwdriver to remove the screws and be careful not to lose the screws.
  10. Toshiba Satellite R15-S829 Hard Drive Replacement: étape 10, image 1 de 1
    • Remove the encasing from the hard drive.
Mike Strother
Membre depuis le 10/20/16
299 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 5-8, Martin Fall 2016 Membre de l'équipe UMass Dartmouth, Team 5-8, Martin Fall 2016
UMASSD-MARTIN-F16S5G8
3 membres
5 tutoriels rédigés
Un commentaire
cual es el numero de parte del flex porfa
Alex De santiago - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 447
