Aller au contenu principal
Toshiba Satellite R15-S829 Keyboard Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite R15-S829 Keyboard Replacement, Battery Replacement: étape 1, image 1 de 1
    • Unplug the charging cable from the laptop.
    • Turn off the laptop.
    • Turn the laptop over and locate the battery.
  2. Toshiba Satellite R15-S829 Keyboard Replacement: étape 2, image 1 de 3 Toshiba Satellite R15-S829 Keyboard Replacement: étape 2, image 2 de 3 Toshiba Satellite R15-S829 Keyboard Replacement: étape 2, image 3 de 3
    • Push the small switch near the corner of the laptop to the unlocked position.
    • Push the bigger switch in the direction of the icon and pull the battery away from the laptop.
  3. Toshiba Satellite R15-S829 Keyboard Replacement, Keyboard Replacement: étape 3, image 1 de 2 Toshiba Satellite R15-S829 Keyboard Replacement, Keyboard Replacement: étape 3, image 2 de 2
    • First, begin by removing the plastic cover that is located at the top of the keyboard. This can be pried off or just removed by hand by grabbing the plastic piece by the indent on either side and lifting up.
    • Be careful to avoid breaking the plastic.
  4. Toshiba Satellite R15-S829 Keyboard Replacement: étape 4, image 1 de 1
    • Locate the two screws on each side.
  5. Toshiba Satellite R15-S829 Keyboard Replacement: étape 5, image 1 de 2 Toshiba Satellite R15-S829 Keyboard Replacement: étape 5, image 2 de 2
    • Remove the two screws with a phillips head screwdriver. Be careful not to lose the screws.
  6. Toshiba Satellite R15-S829 Keyboard Replacement: étape 6, image 1 de 2 Toshiba Satellite R15-S829 Keyboard Replacement: étape 6, image 2 de 2
    • Lift the keyboard up to reveal the power plug.
  7. Toshiba Satellite R15-S829 Keyboard Replacement: étape 7, image 1 de 2 Toshiba Satellite R15-S829 Keyboard Replacement: étape 7, image 2 de 2
    • Disconnect the keyboard from the laptop by unplugging the power ribbon.
Mike Strother
Membre depuis le 10/20/16
299 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 5-8, Martin Fall 2016 Membre de l'équipe UMass Dartmouth, Team 5-8, Martin Fall 2016
UMASSD-MARTIN-F16S5G8
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 211
