Introduction
This battery replacement guide can be used to safely remove and replace the battery from a Toshiba Satellite Radius P55W-B5112 computer. Battery removal is a key step to safely perform further repairs on this computer.
Ce dont vous avez besoin
Unplug your laptop from any source of power.
Lay your laptop on a soft, clean surface as shown.
Using the metal spudger, remove the two rubber grips on the bottom face of the laptop, located closest to the hinge.
Starting on the edge that is opposite the hinge, use the plastic opening tools to pry the back plate away from the computer.
Loosen the three non-hinge edges.
Leave a plastic opening tool in each corner to ensure that one side does not snap closed before you are done opening the others.
To loosen the back plate, lift it slightly and gently pull it away from the hinge.
Flip the back plate open towards the power button, but be sure to not pull on the ribbon cable that connects the back plate to the motherboard.
Use a plastic opening tool to detach the side of the ribbon cable connected to the computer by prying up gently on the small black lever at the point of attachment.
