Aller au contenu principal
Toshiba Satellite Radius P55W-B5220 Motherboard Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement, Motherboard: étape 1, image 1 de 2 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement, Motherboard: étape 1, image 2 de 2
    • Using the plastic opening tool, remove the two rubber feet closest to the hinge.
  2. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 2, image 1 de 1
    • Remove the 12 M2x4mm PH0 Philips screws.
  3. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 3, image 1 de 1
    • Near the hinges, wedge a plastic opening tool under the back panel.
  4. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 4, image 1 de 1
    • Unlatch the LED indicator from the back panel.
  5. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 5, image 1 de 1
    • Using a P0 Philips head screwdriver, Remove the four M2x2.5mm P0 Philips screws from the battery.
  6. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 6, image 1 de 2 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 6, image 2 de 2
    • Lift the battery.
    • Disconnect the battery.
  7. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 7, image 1 de 3 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 7, image 2 de 3 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 7, image 3 de 3
    • Disconnect the ribbon cable of the touchpad from the motherboard.
  8. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 8, image 1 de 2 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 8, image 2 de 2
    • Remove the two M2x2.5mm P0 Philips screws from the fan.
  9. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 9, image 1 de 3 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 9, image 2 de 3 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 9, image 3 de 3
    • Disconnect the fan cables.
    • Carefully unhook the wires from the base of the fan.
  10. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 10, image 1 de 1
    • Unscrew the four M2x4mm PH0 Philips screws from the CPU mounts on the motherboard.
  11. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 11, image 1 de 3 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 11, image 2 de 3 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 11, image 3 de 3
    • Carefully lift the heatsink off the CPU.
    • Avoid bending or kinking the tubing.
    • Delicately lift the fan out with the heatsink.
  12. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 12, image 1 de 1
    • Remove the M2x2.5mm P0 Philips screw from the USB controller.
  13. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 13, image 1 de 3 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 13, image 2 de 3 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 13, image 3 de 3
    • Lift the USB controller from the motherboard.
    • Detach the USB controller from the motherboard.
  14. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 14, image 1 de 1
    • Disconnect the left speaker from the motherboard.
  15. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 15, image 1 de 2 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 15, image 2 de 2
    • Remove the two M2x4mm PH0 Philips screws for the speaker mounts.
  16. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 16, image 1 de 1
    • Unhook the speaker from under the hinge cable mounts.
  17. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 17, image 1 de 1
    • Unhook the right speaker cable from the motherboard.
  18. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 18, image 1 de 1
    • Remove the copper tape from the speaker cord.
  19. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 19, image 1 de 2 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 19, image 2 de 2
    • Unhook the speaker cables from under the catch under the hinge.
  20. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 20, image 1 de 1
    • Remove the eight M2x2.5mm P0 Philips screws from the motherboard.
  21. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: étape 21, image 1 de 1
    • Remove the motherboard.
2 autres ont terminé cette réparation.
Nicole Kohm
Membre depuis le 09/20/17
131 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 14
Total : 1,648
