Aller au contenu principal
Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement, Back Cover: étape 1, image 1 de 1
    • Turn off the laptop before starting.
    • Remove the two rubber feet closest to the hinge with a plastic opening tool.
  2. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement: étape 2, image 1 de 1
    • Remove the twelve M2x4mm PH0 Philips head screws.
  3. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement: étape 3, image 1 de 1
    • Loosen the back cover with a plastic opening tool.
    • The least damaging way to pry the cover is to start from a corner and run the spudger along the edge.
    • Do not crack or bend the cover.
  4. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement: étape 4, image 1 de 1
    • Carefully lift open the cover.
    • Remove the attached purple ribbon cable underneath the cover.
    • Do not rip the ribbon cable.
  5. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement, USB/SD/headphone jack: étape 5, image 1 de 1
    • Unscrew the two screws holding the panel of the UBS/SD card/headphone jack
  6. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement: étape 6, image 1 de 1
    • disconnect the cable shown from the motherboard
  7. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement: étape 7, image 1 de 1
    • disconnect the cable attached to the top of the USB/SD card/headphone jack interface
  8. Toshiba Satellite Radius P55W-B5220 USB/SD/headphone jack Replacement: étape 8, image 1 de 1
    • remove the interface
Garrett barta
Membre depuis le 09/20/17
101 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 10
Total : 390
