Aller au contenu principal
Toshiba Satellite S50-B Cooling Fan Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite S50-B Cooling Fan Replacement, Battery: étape 1, image 1 de 2 Toshiba Satellite S50-B Cooling Fan Replacement, Battery: étape 1, image 2 de 2
    • Make sure you turn off the laptop first.
    • Unscrew the two 6.5mm screws below the battery using a Phillips #0 Screwdriver.
  2. Toshiba Satellite S50-B Cooling Fan Replacement: étape 2, image 1 de 2 Toshiba Satellite S50-B Cooling Fan Replacement: étape 2, image 2 de 2
    • Place thumbs on corners of the battery. Pinch the battery between the thumb and index finger and pull.
  3. Toshiba Satellite S50-B Cooling Fan Replacement, Cooling Fan: étape 3, image 1 de 3 Toshiba Satellite S50-B Cooling Fan Replacement, Cooling Fan: étape 3, image 2 de 3 Toshiba Satellite S50-B Cooling Fan Replacement, Cooling Fan: étape 3, image 3 de 3
    • Locate the 10 screws on the bottom of the device, there should be 12 screws in total including the battery screws. Unscrew using a Phillips #0 screwdriver, and set screws aside.
    • Use a plastic opening tool to remove the bottom panel.
  4. Toshiba Satellite S50-B Cooling Fan Replacement: étape 4, image 1 de 3 Toshiba Satellite S50-B Cooling Fan Replacement: étape 4, image 2 de 3 Toshiba Satellite S50-B Cooling Fan Replacement: étape 4, image 3 de 3
    • Locate the 2 screws on each fan. Unscrew them.
    • Disconnect the fan by applying gentle pressure to the circled connection with your finger and pulling.
    • Remove the fans. Be sure to keep track of the right and left fans, marked R and L.
diana calvo
Membre depuis le 10/17/17
144 Réputation
1 tutoriel rédigé
Équipe
UC Santa Barbara, Team S1-G4, Weedon Fall 2017 Membre de l'équipe UC Santa Barbara, Team S1-G4, Weedon Fall 2017
UCSB-WEEDON-F17S1G4
5 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 8
30 derniers jours : 11
Total : 1,536
