Aller au contenu principal
Toshiba Satellite S55t-A5389 Processor Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite S55t-A5389 Processor Replacement, Battery: étape 1, image 1 de 1
    • Remove the fourteen 5mm Phillips #0 screws from the bottom of the laptop.
  2. Toshiba Satellite S55t-A5389 Processor Replacement: étape 2, image 1 de 1
    • Using the plastic prying tools, go around the edge of the bottom of the laptop to release the cover.
  3. Toshiba Satellite S55t-A5389 Processor Replacement: étape 3, image 1 de 3 Toshiba Satellite S55t-A5389 Processor Replacement: étape 3, image 2 de 3 Toshiba Satellite S55t-A5389 Processor Replacement: étape 3, image 3 de 3
    • Remove the four 5mm Phillips #0 screws from the battery.
    • Unplug the battery from the motherboard.
    • Remove the battery from the laptop.
  4. Toshiba Satellite S55t-A5389 Processor Replacement, Processor Fan: étape 4, image 1 de 1
    • Remove the two 5mm Phillips #0 screws from the fan.
  5. Toshiba Satellite S55t-A5389 Processor Replacement: étape 5, image 1 de 1
    • Disconnect the fan from the motherboard.
  6. Toshiba Satellite S55t-A5389 Processor Replacement: étape 6, image 1 de 1
    • Remove the four 5mm Phillips #0 screws from the heat pipe.
    • Remove the fan and heat pipe from the laptop.
  7. Toshiba Satellite S55t-A5389 Processor Replacement, Processor: étape 7, image 1 de 1
    • Rotate the lock 90 degrees using a Torx T8 in order to remove the processor.
  8. Toshiba Satellite S55t-A5389 Processor Replacement: étape 8, image 1 de 1
    • Carefully lift up the processor.
    • When putting the new processor on, make sure that the little arrow on the processor matches with the arrow on the socket
3 autres ont terminé cette réparation.
William Mazanec
Membre depuis le 01/29/18
1 374 Réputation
8 tutoriels rédigés
Équipe
USF Tampa, Team S5-G6, Passmore Spring 2018 Membre de l'équipe USF Tampa, Team S5-G6, Passmore Spring 2018
USFT-PASSMORE-S18S5G6
3 membres
8 tutoriels rédigés
Un commentaire
Can i use i7 4940mx cpu on this laptop
Movies Star - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 686
