Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
If your laptop no longer runs as well as it did, and has become slow, unresponsive, or does not power on. You're processor may be at fault and replacing it could be an option. However before this is done, be sure to check your laptop for any viruses, or any other issues that it may have.
  1. Remove the fourteen 5mm Phillips #0 screws from the bottom of the laptop.
    • Remove the fourteen 5mm Phillips #0 screws from the bottom of the laptop.
  2. Using the plastic prying tools, go around the edge of the bottom of the laptop to release the cover.
    • Using the plastic prying tools, go around the edge of the bottom of the laptop to release the cover.
  3. Remove the four 5mm Phillips #0 screws from the battery. Unplug the battery from the motherboard. Remove the battery from the laptop.
    • Remove the four 5mm Phillips #0 screws from the battery.
    • Unplug the battery from the motherboard.
    • Remove the battery from the laptop.
  4. SAUTEZ LA MISE À NIVEAU
    Économisez en réparant avec un kit tout-en-un.
    Fix Kits pour iPhone
  5. Remove the two 5mm Phillips #0 screws from the fan.
    • Remove the two 5mm Phillips #0 screws from the fan.
  6. Disconnect the fan from the motherboard.
    • Disconnect the fan from the motherboard.
  7. Remove the four 5mm Phillips #0 screws from the heat pipe.
    • Remove the four 5mm Phillips #0 screws from the heat pipe.
    • Remove the fan and heat pipe from the laptop.
  8. Rotate the lock 90 degrees using a Torx T8 in order to remove the processor.
    • Rotate the lock 90 degrees using a Torx T8 in order to remove the processor.
  9. Carefully lift up the processor.
    • Carefully lift up the processor.
    • When putting the new processor on, make sure that the little arrow on the processor matches with the arrow on the socket
William Mazanec
Membre depuis le 29/01/2018
1 236 Réputation
8 tutoriels rédigés
Équipe
USF Tampa, Team S5-G6, Passmore Spring 2018 Membre de l'équipe USF Tampa, Team S5-G6, Passmore Spring 2018
USFT-PASSMORE-S18S5G6
3 membres
8 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 263
