Aller au contenu principal
Toshiba Satellite U405D-S2902 Display Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite U405D-S2902 Display Replacement, Display: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    • Use tweezers to remove the small rubber covers over the screws on the top and bottom of the laptop case.
  2. Toshiba Satellite U405D-S2902 Display Replacement: étape 2, image 1 de 2 Toshiba Satellite U405D-S2902 Display Replacement: étape 2, image 2 de 2
    • Use a #1 Phillips screwdriver to remove the 3mm screws located on both sides of the top of the laptop as well as the lower corners.
  3. Toshiba Satellite U405D-S2902 Display Replacement: étape 3, image 1 de 3 Toshiba Satellite U405D-S2902 Display Replacement: étape 3, image 2 de 3 Toshiba Satellite U405D-S2902 Display Replacement: étape 3, image 3 de 3
    • Use a plastic opening tool to separate the front plastic panel from the back side of the top of the laptop.
    • Carefully pull the top away from the back.
  4. Toshiba Satellite U405D-S2902 Display Replacement: étape 4, image 1 de 3 Toshiba Satellite U405D-S2902 Display Replacement: étape 4, image 2 de 3 Toshiba Satellite U405D-S2902 Display Replacement: étape 4, image 3 de 3
    • Turn the laptop around.
    • Remove the webcam/microphone data cable.
  5. Toshiba Satellite U405D-S2902 Display Replacement: étape 5, image 1 de 2 Toshiba Satellite U405D-S2902 Display Replacement: étape 5, image 2 de 2
    • Remove the lower lighting power supply.
    • Remove the signal light power supply and data cable.
  6. Toshiba Satellite U405D-S2902 Display Replacement: étape 6, image 1 de 2 Toshiba Satellite U405D-S2902 Display Replacement: étape 6, image 2 de 2
    • Locate and remove the four 2mm #1 Phillips screws around the sidewalls of the display.
    • After removing the last screw, the screen will be very loose, be sure to keep a hand on it to prevent it from damaging the keyboard.
  7. Toshiba Satellite U405D-S2902 Display Replacement: étape 7, image 1 de 2 Toshiba Satellite U405D-S2902 Display Replacement: étape 7, image 2 de 2
    • Carefully remove the screen from the side brackets.
    • Remove the LCD ribbon connector from the display.
4 autres ont terminé cette réparation.
Brandon Kirklen
Membre depuis le 01/11/13
311 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 7-8, Maness Winter 2013 Membre de l'équipe Cal Poly, Team 7-8, Maness Winter 2013
CPSU-MANESS-W13S7G8
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 723
