Aller au contenu principal
Toshiba Satellite U405D-S2902 Faceplate Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite U405D-S2902 Faceplate Replacement, Battery: étape 1, image 1 de 1
    • Make sure that the laptop is off and unplugged.
    • Turn the laptop over.
    • Slide back the left lock, and you should hear a click when it is successfully locked back in.
  2. Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 2, image 1 de 1
    • Rotate the laptop 180 degrees so that the battery is near you.
    • Hold back the spring slide and pull the battery out.
  3. Toshiba Satellite U405D-S2902 Faceplate Replacement, Keyboard: étape 3, image 1 de 3 Toshiba Satellite U405D-S2902 Faceplate Replacement, Keyboard: étape 3, image 2 de 3 Toshiba Satellite U405D-S2902 Faceplate Replacement, Keyboard: étape 3, image 3 de 3
    • Situate the laptop so that it is open and the display is facing you.
    • Use the plastic opening tool to pry the black plastic insert upward. The insert can be found at the top of the keyboard.
    • Once the insert is loose, carefully remove it from the device.
  4. Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 4, image 1 de 2 Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 4, image 2 de 2
    • Using #1 Phillips Screwdriver, remove both of the 5 mm screws that are located beneath the insert.
  5. Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 5, image 1 de 2 Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 5, image 2 de 2
    • Use the plastic opening tool to begin removing the keys off of the device.
    • Once the keys are off, gently remove the keyboard. Be careful of the ribbon cable that still connects the keyboard to motherboard.
  6. Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 6, image 1 de 2 Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 6, image 2 de 2
    • Lift up the gate on the ZIF socket to release the ribbon.
    • Ease the ribbon connecting the keyboard to the motherboard out of the ZIF socket.
  7. Toshiba Satellite U405D-S2902 Faceplate Replacement, Faceplate: étape 7, image 1 de 2 Toshiba Satellite U405D-S2902 Faceplate Replacement, Faceplate: étape 7, image 2 de 2
    • With the keyboard removed, locate the marked screws.
    • Remove the marked, 5mm screws using the #1 Phillips Screwdriver.
  8. Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 8, image 1 de 2 Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 8, image 2 de 2
    • In the opening above the mouse pad, use the plastic opening tool to push up the black gate of the ZIF socket.
    • Remove the ribbon from the ZIF socket.
  9. Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 9, image 1 de 3 Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 9, image 2 de 3 Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 9, image 3 de 3
    • Locate the wide opening at the top near the screen.
    • Use the plastic opening tool to open the black ZIF socket.
    • Remove the blue ribbon.
  10. Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 10, image 1 de 2 Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 10, image 2 de 2
    • After removing the screw in step 3, carefully close the laptop and put it face down. Locate the center panel.
    • Remove the three, 3 mm screws using the #1 Phillips Screwdriver.
  11. Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 11, image 1 de 2 Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 11, image 2 de 2
    Outil utilisé dans cette étape :
    • Grasp the power cable with your tweezers and remove it from the wireless antenna.
  12. Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 12, image 1 de 2 Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 12, image 2 de 2
    • Locate and remove both the white and black antenna leads with the tweezers.
  13. Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 13, image 1 de 3 Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 13, image 2 de 3 Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 13, image 3 de 3
    • Remove screws for back assembly.
    • 11 x F5 (5 mm #1 Phillips)
    • 6 x F2 (2 mm #0 Phillips)
    • 4 x F8 (8 mm #1 Phillips)
    • 1 x F3 (3 mm #1 Phillips
  14. Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 14, image 1 de 1
    • Use the plastic opening tool to release the back panel from the laptop.
    • If all of the screws are removed it should come off with very little effort. Do not force it. If it still feels attached, check that you didn't miss a screw or two.
  15. Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 15, image 1 de 2 Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 15, image 2 de 2
    • Use the plastic opening tool to separate the top faceplate.
    • The faceplate is the plastic surface and the metal piece under the keyboard.
    • Carefully lift the faceplate off of the base by sliding the plastic opening tool around the outside of the device. You'll hear clicks as you do this.
    • Prying apart the faceplate will be a little hard, but try not to bend it too much - you do not want to crack it.
  16. Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 16, image 1 de 1
    • Lift the back panel and carefully disconnect the main power cable.
  17. Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 17, image 1 de 2 Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 17, image 2 de 2
    • Remove the black signal cable attached at the blue circuit board.
  18. Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 18, image 1 de 2 Toshiba Satellite U405D-S2902 Faceplate Replacement: étape 18, image 2 de 2
    • Remove auxiliary power cable attached to the blue board at the back of the laptop.
Brandon Kirklen
Membre depuis le 01/11/13
311 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 7-8, Maness Winter 2013 Membre de l'équipe Cal Poly, Team 7-8, Maness Winter 2013
CPSU-MANESS-W13S7G8
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 937
