Aller au contenu principal
Toshiba Satellite c650d Fan Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite c650d Fan Replacement, Battery: étape 1, image 1 de 1
    • Unplug the laptop and turn it off.
    • Flip the laptop upside down.
    • Locate the battery on the underside of the laptop.
  2. Toshiba Satellite c650d Fan Replacement: étape 2, image 1 de 1
    • Push the two latches away from the battery.
  3. Toshiba Satellite c650d Fan Replacement: étape 3, image 1 de 2 Toshiba Satellite c650d Fan Replacement: étape 3, image 2 de 2
    • Slide the battery away from the laptop.
    • Locate the serial number on the battery to order a replacement.
  4. Toshiba Satellite c650d Fan Replacement, Keyboard: étape 4, image 1 de 1
    • Remove the fourteen 6.0mm and two 2.0mm Philip's #0 screws connecting the keyboard to the back.
    • Make sure you keep track of all the screws.
  5. Toshiba Satellite c650d Fan Replacement: étape 5, image 1 de 1
    • Flip the computer over.
    • Use a nylon spudger to lift the keyboard.
    • Go around the edge of the keyboard and lift until the keyboard separates from the back.
    • Only lift the keyboard a little at a time, otherwise you risk damaging the plastic.
  6. Toshiba Satellite c650d Fan Replacement: étape 6, image 1 de 1
    • Detach the ribbon cable that connects the keyboard to the motherboard.
  7. Toshiba Satellite c650d Fan Replacement, Fan: étape 7, image 1 de 1
    • Detach the cable connecting the fan to the motherboard.
  8. Toshiba Satellite c650d Fan Replacement: étape 8, image 1 de 2 Toshiba Satellite c650d Fan Replacement: étape 8, image 2 de 2
    • Remove the one 3.0mm and one 5.0mm Philips #0 screws holding the fan in place.
  9. Toshiba Satellite c650d Fan Replacement: étape 9, image 1 de 1
    • Remove the fan by pulling it out slowly.
4 autres ont terminé cette réparation.
Brenna Callahan
Membre depuis le 10/21/15
868 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015 Membre de l'équipe UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G2
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 12
Total : 1,420
