Aller au contenu principal
Toshiba Satellite e205 Keyboard Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite e205 Keyboard Replacement, Battery: étape 1, image 1 de 2 Toshiba Satellite e205 Keyboard Replacement, Battery: étape 1, image 2 de 2
    • With the battery away from you, slide the locking clips out.
    • The left clip stays, the right clip is spring loaded.
    • Slide the battery away from you.
  2. Toshiba Satellite e205 Keyboard Replacement, Keyboard: étape 2, image 1 de 1
    • Use a spudger to carefully pry up the keyboard screw cover.
  3. Toshiba Satellite e205 Keyboard Replacement: étape 3, image 1 de 1
    • Remove the two screws securing the keyboard to the chassis.
  4. Toshiba Satellite e205 Keyboard Replacement: étape 4, image 1 de 1
    • Carefully tilt the keyboard towards you and release the ribbon cables.
    • Use a spudger if needed to release the latch. The latch slides out.
    • The keyboard is now free and can be set aside.
2 autres ont terminé cette réparation.
Tyler
Membre depuis le 06/19/12
5 031 Réputation
16 tutoriels rédigés
Équipe
TechForce Membre de l'équipe TechForce
Business
2 membres
29 tutoriels rédigés
2 commentaires
What is the brass colored ribbon for? Mine is broken will it effect funconality , if so how do i fix it
Kathleen T - Réponse
If I remember correctly, this keyboard is backlit. Most likely the copper cable is for the backlit power. A new keyboard would need to be purchased to fix it.
Tyler - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 11
Total : 693
