Aller au contenu principal
Toshiba Satellite e205 Motherboard Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite e205 Motherboard Replacement, Battery: étape 1, image 1 de 2 Toshiba Satellite e205 Motherboard Replacement, Battery: étape 1, image 2 de 2
    • With the battery away from you, slide the locking clips out.
    • The left clip stays, the right clip is spring loaded.
    • Slide the battery away from you.
  2. Toshiba Satellite e205 Motherboard Replacement, Keyboard: étape 2, image 1 de 1
    • Use a spudger to carefully pry up the keyboard screw cover.
  3. Toshiba Satellite e205 Motherboard Replacement: étape 3, image 1 de 1
    • Remove the two screws securing the keyboard to the chassis.
  4. Toshiba Satellite e205 Motherboard Replacement: étape 4, image 1 de 1
    • Carefully tilt the keyboard towards you and release the ribbon cables.
    • Use a spudger if needed to release the latch. The latch slides out.
    • The keyboard is now free and can be set aside.
  5. Toshiba Satellite e205 Motherboard Replacement, Bottom Cover: étape 5, image 1 de 1
    • Remove the five black screws
    • Remove the one silver screw
  6. Toshiba Satellite e205 Motherboard Replacement: étape 6, image 1 de 1
    • Flip the laptop over so the bottom is facing up.
    • Using a spudger, remove the seven rubber inserts.
    • The feet only go in one location on the bottom of the laptop, so save yourself some time and track where they go.
  7. Toshiba Satellite e205 Motherboard Replacement: étape 7, image 1 de 1
    • Remove the six silver screws.
    • Remove the one black screw.
  8. Toshiba Satellite e205 Motherboard Replacement: étape 8, image 1 de 2 Toshiba Satellite e205 Motherboard Replacement: étape 8, image 2 de 2
    • Stand the laptop up on end.
    • Remove the two rubber inserts from the back of the laptop. One insert is on each side of the laptop.
  9. Toshiba Satellite e205 Motherboard Replacement: étape 9, image 1 de 2 Toshiba Satellite e205 Motherboard Replacement: étape 9, image 2 de 2
    • Remove the two screews.
  10. Toshiba Satellite e205 Motherboard Replacement: étape 10, image 1 de 1
    • Carefully work a spudger in the crack at the back of the laptop and separate the small rubberized section from the bottom of the laptop.
  11. Toshiba Satellite e205 Motherboard Replacement: étape 11, image 1 de 1
    • Remove the four screws.
    • Disconnect the black wireless antenna lead.
  12. Toshiba Satellite e205 Motherboard Replacement: étape 12, image 1 de 1
    • The bottom of the laptop is now ready to lift off.
    • Carefully work a spudger around the seam of the laptop separating the bottom from the rest of the laptop.
    • There is a data connection at the front of the laptop that needs to be disconnected.
    • Use a spuder to carefully disconnect the wire from the motherboard. Once this is free the bottom will come off.
  13. Toshiba Satellite e205 Motherboard Replacement, Hard Drive: étape 13, image 1 de 2 Toshiba Satellite e205 Motherboard Replacement, Hard Drive: étape 13, image 2 de 2
    • Locate the hard drive.
    • Remove the three screws.
    • Slide the hard drive out away from the motherboard connector.
    • Once the hard drive is disconnected it lifts out.
  14. Toshiba Satellite e205 Motherboard Replacement, Wireless Card: étape 14, image 1 de 2 Toshiba Satellite e205 Motherboard Replacement, Wireless Card: étape 14, image 2 de 2
    • Locate the wireless card.
    • Remove the white antenna lead.
    • Remove the single screw.
    • Lift the card up from the edge with the screw, and pull out.
  15. Toshiba Satellite e205 Motherboard Replacement, Optical Drive: étape 15, image 1 de 2 Toshiba Satellite e205 Motherboard Replacement, Optical Drive: étape 15, image 2 de 2
    • Locate optical drive
    • Remove the three screws securing the optical drive.
    • Slide the optical drive away from the motherboard, and carefully lift up.
  16. Toshiba Satellite e205 Motherboard Replacement, Motherboard: étape 16, image 1 de 1
    • Carefully flip the laptop rightside up and open the lid.
    • Disconnect the cables from the motherboard.
  17. Toshiba Satellite e205 Motherboard Replacement: étape 17, image 1 de 2 Toshiba Satellite e205 Motherboard Replacement: étape 17, image 2 de 2
    • Close the laptop lid, and flip back over so you see the motherboard.
    • Disconnect all cables from the motherboard.
    • This wire holder is stuck on with a little glue and should lift right off.
  18. Toshiba Satellite e205 Motherboard Replacement: étape 18, image 1 de 1
    • Remove the heatsink screws. And lift up the heatsink.
    • The screws remain attached to the heatsink.
    • Remove the three screws holding the motherboard to the chasis.
  19. Toshiba Satellite e205 Motherboard Replacement: étape 19, image 1 de 1
    • Lift up on ribbon cable latch.
    • Gently disconnect ribbon cable from motherboard.
    • The motherboard should lift out.
Tyler
Membre depuis le 06/19/12
4 920 Réputation
16 tutoriels rédigés
Équipe
TechForce Membre de l'équipe TechForce
Business
2 membres
25 tutoriels rédigés
3 commentaires
This guide could really use an explanation of how to disconnect the different types of cables from the motherboard. In particular, the descriptions for steps 16 and 17 are completely inadequate to me.
gitm - Réponse
Also, to replace the motherboard you must remove the CPU and RAM from the motherboard, so they can be connected to the new one. This guide does not cover that.
gitm -
Anther important omission is the data connection to the card reader, which needs to be disconnected in Step 11 (this is one of two connections between the motherboard and the bottom of the case).
gitm -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 886
