Introduction
If you need to replace the hard drive, follow this guide. The hard drive is located underneath the computer. To replace this part, you will need a Phillips 00 screw driver and a plastic prying tool. This process should not require any excessive force.
Ce dont vous avez besoin
Remove the battery by sliding the tabs to the left.
Use the spudger to lift the battery out.
