Introduction
If a fan stops working all together on this device, then replacing it can be a good way to save money over buying a new projector. This guide will show how to get to and replace this part.
Start by removing the two screws on the bottom of the device as shown.
  • Start by removing the two screws on the bottom of the device as shown.
Ajouter un commentaire
Remove the top plastic cover from the device. The back is snapped on so it would help to have leverage from a prying tool.
  • Remove the top plastic cover from the device. The back is snapped on so it would help to have leverage from a prying tool.
  • Remove the ribbon cable attached to the plastic piece just removed. Remember its orientation for re-assembling later.
  • Remove the screws from the case located around the device.
Three screws?
lkmemphis - Réponse
  • Remove the plastic panels from the body.
“X Honeycomb panels” How many panels are removed?
lkmemphis - Réponse
  • Remove the screws from the IO panel.
  • Pull up on the panel and remove it.
Again, how many screws?
lkmemphis - Réponse
  • Unscrew the screws from the metal shielding to remove it.
How many screws?
lkmemphis - Réponse
  • Remove cables from motherboard.
  • Unscrew motherboard and remove from device.
Any warnings about handling the motherboard?
lkmemphis - Réponse
  • Remove the cable from the bottom of the motherboard to fully remove it.
  • Unscrew the power adapter on the back.
  • Remove cables from the power supply board.
  • Remove the screws located around the board to un-mount it.
  • Remove the power board to reveal the bottom two screws to the fan.
  • Unscrew the fan and replace it with an equivalent one.
Bryan Underwood
Membre depuis le 02/04/2018
697 Réputation
5 tutoriels rédigés
Équipe
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 17
