Aller au contenu principal
Toshiba TDP-XP2 Fuse Replacement
Ce dont vous avez besoin
  1. Toshiba TDP-XP2 Fuse Replacement, Fuse: étape 1, image 1 de 3 Toshiba TDP-XP2 Fuse Replacement, Fuse: étape 1, image 2 de 3 Toshiba TDP-XP2 Fuse Replacement, Fuse: étape 1, image 3 de 3
    • Start by removing the two screws on the bottom of the device as shown.
  2. Toshiba TDP-XP2 Fuse Replacement: étape 2, image 1 de 2 Toshiba TDP-XP2 Fuse Replacement: étape 2, image 2 de 2
    • Remove the top plastic cover from the device. The back is snapped on so it would help to have leverage from a prying tool.
    • Remove the ribbon cable attached to the plastic piece just removed. Remember its orientation for re-assembling later.
  3. Toshiba TDP-XP2 Fuse Replacement: étape 3, image 1 de 3 Toshiba TDP-XP2 Fuse Replacement: étape 3, image 2 de 3 Toshiba TDP-XP2 Fuse Replacement: étape 3, image 3 de 3
    • Remove the screws from the case located around the device.
  4. Toshiba TDP-XP2 Fuse Replacement: étape 4, image 1 de 1
    • Remove the plastic panels from the body.
  5. Toshiba TDP-XP2 Fuse Replacement: étape 5, image 1 de 3 Toshiba TDP-XP2 Fuse Replacement: étape 5, image 2 de 3 Toshiba TDP-XP2 Fuse Replacement: étape 5, image 3 de 3
    • Remove the screws from the IO panel.
    • Pull up on the panel and remove it.
  6. Toshiba TDP-XP2 Fuse Replacement: étape 6, image 1 de 2 Toshiba TDP-XP2 Fuse Replacement: étape 6, image 2 de 2
    • Unscrew the screws from the metal shielding to remove it.
  7. Toshiba TDP-XP2 Fuse Replacement: étape 7, image 1 de 3 Toshiba TDP-XP2 Fuse Replacement: étape 7, image 2 de 3 Toshiba TDP-XP2 Fuse Replacement: étape 7, image 3 de 3
    • Remove cables from motherboard.
    • Unscrew motherboard and remove from device.
  8. Toshiba TDP-XP2 Fuse Replacement: étape 8, image 1 de 1
    • Remove the cable from the bottom of the motherboard to fully remove it.
  9. Toshiba TDP-XP2 Fuse Replacement: étape 9, image 1 de 1
    • Unscrew the power adapter on the back.
  10. Toshiba TDP-XP2 Fuse Replacement: étape 10, image 1 de 2 Toshiba TDP-XP2 Fuse Replacement: étape 10, image 2 de 2
    • Remove cables from the power supply board.
    • Remove the screws located around the board to un-mount it.
  11. Toshiba TDP-XP2 Fuse Replacement: étape 11, image 1 de 2 Toshiba TDP-XP2 Fuse Replacement: étape 11, image 2 de 2
    • Locate the fuse near where the power adapter was.
    • De-solder the fuse and replace with an equivalent fuse (Fuse leads to de-solder are marked in red).
Bryan Underwood
Membre depuis le 04/02/18
697 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 11
Total : 368
