Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
The hard drive is one of the most simple part replacements to perform on this computer. A screwdriver and prying tool are the only tools needed.
Pièces
Aucune pièce spécifiée.
  1. Loosen the screw holding the back panel for RAM in place using a Phillips #0 screwdriver. Once loosened, lift the panel up and set it aside. The screw holding the panel in place should not come completely out. If it does, do not be alarmed as it will still screw back in.
    • Loosen the screw holding the back panel for RAM in place using a Phillips #0 screwdriver. Once loosened, lift the panel up and set it aside.
    • The screw holding the panel in place should not come completely out. If it does, do not be alarmed as it will still screw back in.
  2. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  3. Remove the 11mm screw from the right side of the hard drive access panel using a Phillips #0 screwdriver. Remove the 3.5 mm screw from the left side of the access panel using a Phillips #0 screwdriver.
    • Remove the 11mm screw from the right side of the hard drive access panel using a Phillips #0 screwdriver.
    • Remove the 3.5 mm screw from the left side of the access panel using a Phillips #0 screwdriver.
    • Use a plastic opening tool to pry off the access panel from the bottom.
  4. Gently lift the hard drive from the left side and disconnect the SATA connector from the right side. Completely remove the hard drive. Gently lift the hard drive from the left side and disconnect the SATA connector from the right side. Completely remove the hard drive.
    • Gently lift the hard drive from the left side and disconnect the SATA connector from the right side. Completely remove the hard drive.
Holly Strauch
Membre depuis le 23/09/2018
409 Réputation
4 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 16
Total : 307
