Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
This guide would be useful for replacing broken RAM or upgrading the working RAM to make your Toshiba TECRA R940 run better.
This laptop has a comparatively easy procedure to replace RAM.
Pièces
Aucune pièce spécifiée.
  1. Unscrew the screw attached to the small back panel, and set the back panel aside. The screw should not come completely out of the hole when unscrewed. If it does, do not be alarmed as it will still screw back in.
    • Unscrew the screw attached to the small back panel, and set the back panel aside.
    • The screw should not come completely out of the hole when unscrewed. If it does, do not be alarmed as it will still screw back in.
  2. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  3. Pull the metal brackets away from the RAM card to unlock it from the slot, then pull the RAM card out. When handling the RAM cards try not to touch the gold colored metal at the base, as this could cause the cards to malfunction. Best practice is to try and hold the cards by the edges.
    • Pull the metal brackets away from the RAM card to unlock it from the slot, then pull the RAM card out.
    • When handling the RAM cards try not to touch the gold colored metal at the base, as this could cause the cards to malfunction. Best practice is to try and hold the cards by the edges.
  4. Repeat the previous step of pulling the RAM card out for the second card, but using the lower brackets. Repeat the previous step of pulling the RAM card out for the second card, but using the lower brackets.
    • Repeat the previous step of pulling the RAM card out for the second card, but using the lower brackets.
Jack Dutton
Membre depuis le 23/09/2018
389 Réputation
3 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 2
Total : 167
